07 Sportsman 800 hitting rev limiter
Old Jan 26, 2008 | 03:14 PM
bmitch0675's Avatar
Default 07 Sportsman 800 hitting rev limiter
Hey guys, I have a 800 with 18 hrs on it. It seems to hit the hit the rev limiter in low gear quicker than before. I also noticed it will move a little while in gear at idle. Any suggestions would be appreciated.
Old Jan 26, 2008 | 03:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its low range you might hit the limiter if you push it past 18 to 20mph. have you burned the belt at any time. the only reasons it would try to move ahead is if the ebs bushing is bad or maybe the belt is junk. what is it idling at for rpms?
Old Jan 26, 2008 | 04:25 PM
Blacksheep5's Avatar
I noticed mine doing that before the belt broke, check your front lower engine mount to make sure its not broken.
Old Jan 26, 2008 | 04:41 PM
bmitch0675's Avatar
It idles between 850 and 900 rpm's. I'm not sure if I smoked the belt. Last fall I had to pull alot of seed (around 1000 pds) on a trailer to plant deer feilds. There were some pretty steep hills and the side cover felt a little warm to me.
Another thing is I had a 05 700 (carb) that would wheelie in Hi or Lo sitting on the seat. The only way I can get the 800 up is in Lo with my foot on the back rack.
Old Jan 26, 2008 | 04:47 PM
bmitch0675's Avatar
Blacksheep, I saw your thread on that and I checked mine. I cant see any movement at all on the front mount. I'm guessing its ok.
Old Jan 26, 2008 | 09:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first off it should be idling at 1150 +- rpm. w/ stock wheels in high it should at least bring up the front a little. if you were hauling that kind off weight you should have had it in L.range. its possaible that you did burn the belt. take the cover off and check it out. even test it w/ the cover off just watch out for the clutch that you dont get anything caught in it. let us know.
Old Jan 26, 2008 | 09:36 PM
bmitch0675's Avatar
Yeah I keep it in Lo anytime I haul or drive on steep hills. I'll take the cover off tommorow and let you know. Thanks for the help.
Old Jan 27, 2008 | 07:25 PM
bmitch0675's Avatar
Ok, I took the belt off, it looks ok to me. What should I be looking for?
Old Jan 27, 2008 | 09:29 PM
1smokin50's Avatar
My Scrambler just started lurching in gear, so I took off the cover and the clutch isn't fully disengaging!!! It's got a stiff spot in it so now I have to pull the clutch and probably replace the bushings!!!
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Jun 16, 2016 09:07 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
