07 Sportsman 800 hitting rev limiter
It idles between 850 and 900 rpm's. I'm not sure if I smoked the belt. Last fall I had to pull alot of seed (around 1000 pds) on a trailer to plant deer feilds. There were some pretty steep hills and the side cover felt a little warm to me.
Another thing is I had a 05 700 (carb) that would wheelie in Hi or Lo sitting on the seat. The only way I can get the 800 up is in Lo with my foot on the back rack.
first off it should be idling at 1150 +- rpm. w/ stock wheels in high it should at least bring up the front a little. if you were hauling that kind off weight you should have had it in L.range. its possaible that you did burn the belt. take the cover off and check it out. even test it w/ the cover off just watch out for the clutch that you dont get anything caught in it. let us know.
cody500ho
14
08-14-2015 05:03 PM
Mojave250A
07-11-2015 10:38 AM
