01' rubi cannot retrieve codes
Old Jan 26, 2008 | 04:46 PM
01' rubi's Avatar
Default 01' rubi cannot retrieve codes
I just purchased an 01' rubicon that is stuck in fault mode. The display blinks, cuts out in reverse, and says its going 0 all the time. It came with a honda service manual and I followed the code retrieval method, but it just continually blinks. I tried the reset procedure and still the same. Its just continous blink with no different spacing between blinks. When you take off when its cold it will work for maybe a minute. It seems to work a good while in esp mode if I'm just putting around in the first few gears. then when I get on it it will fault out. When it is working properly, reverse works fine. no cutting out. But the MPH gauge does not work ever. I bought the quad this way and the previous owner just put a new timing chain in it. It runs great I just wish I could fix this thing and make it ridable. thanks ahead for any advice.
Old Jan 26, 2008 | 05:36 PM
rubiconcaesar's Avatar
Wish I could help. I have a 01 Rubicon doing kind of the same thing. On the instrument cluster, it's blinking a code, in reverse it barely moves then cuts on and off. Seems to be stuck in high gear. The only thing I could tell it might be is the shift solenoid or at least that's what I think it's called on the left side of the engine going into the transmission. When I turn the key on, the solenoid seems to engage and make a noise for a couple seconds. Any help would be greatly appreciated!
Old Jan 27, 2008 | 11:22 AM
01' rubi's Avatar
can you tell what code yours is putting out?
Old Jan 27, 2008 | 11:28 AM
cluby's Avatar
Sounds like a bad angle sensor, sometimes it will just stay blinking untill you replace it.
Old Jan 27, 2008 | 02:44 PM
Wheres the angle sensor located and would this happen if its a angle sensor. I turned the switch on and off about ten times then it cleared out and started shifting fine . It set then I went back the problem reappeared .Problem being cuts back in reverse and not shifting and instrument cluster blinking instead of the gear it's in showing...
Old Jan 27, 2008 | 02:45 PM
01 rubi I can't get a code it's just blinking .
Old Jan 27, 2008 | 05:35 PM
cluby's Avatar
The angle sensor is on the left side behind the plastic cover over the exhaust. Yes this can make the screen just blink and not be able to pull up a code.
Old Jan 27, 2008 | 05:57 PM
Thx cluby
Old Jan 27, 2008 | 08:28 PM
01' rubi's Avatar
Yeah, Thanks cluby. sounds like I should try an angle sensor first. I read somewere that you had to preload those before install? Also I wonder if that would make my MPH gauge not work? Thanks
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
