arctic cat runns at idol and fine fer a while....then dies...neeed help pleese
Old Jan 27, 2008 | 06:51 PM
Acat454's Avatar
Default arctic cat runns at idol and fine fer a while....then dies...neeed help pleese
I have a 98 arctic cat 454 and it will run fine at and idol but as soon as its riddin for 5 minutes it will die as if someone has turned the key off...just quits no back fireing or anthing...anyone have any ideas?
Old Jan 28, 2008 | 09:24 PM
Fossil's Avatar
"If you haven't any charity in your heart, you have the worst kind of heart trouble." ~Bob Hope
Don't know anything about the 454 but check your gas tank vent to be sure the hose is not kinked. A number of people have had this problem which causes the atv to stall. Try running it at idle with the fuel cap off to see if that's the issue. Hope that helps. You might also try running some Sea Foam through it. If you have a dirty carb that will mosdt likley clean it out.
Old Jan 31, 2008 | 11:35 AM
62Handler's Avatar
my first thought would be a partially plugged fuel filter or a carb issue. i had an old john deere snowmobile that did this and never figured out what it was, replaced the fuel filter and had the carb rebuilt but no help.
is it predictable? meaning does it always seem to stall at about the same run time
if so i would think fuel, if it varries with temp then it could be a heat soak issue meaning that as something gets hot it starts failing (coil, vaporlock in the fuel line...)
how long before it will restart?
Nondem
Feb 22, 2020 12:20 PM
Mar 4, 2017 12:24 AM
Aug 11, 2015 03:42 AM
Club News and Events
Jul 23, 2015 02:04 AM
Gtsordo
Jul 13, 2015 10:38 PM
