anyone used the fmf jet kit with the exhaust?
Old Jan 27, 2008 | 09:04 PM
suprdavtn's Avatar
Default anyone used the fmf jet kit with the exhaust?
when i read old post my kit does not match jet size or needle colors. yall have any experiance with this kit.
Old Jan 28, 2008 | 05:35 PM
BZaj's Avatar
Hi, I have a HMF header and exhaust. With it it also came with a "jet kit", but I ended up ordering the biggest kit that polaris makes and having to turn the main needle out an extra 1.75 turns to make it ruin smoothely. I guess I would suggest the same. ( At the time I also put in a complete after market intake system as well), which would possibly make my "settings" to my jets a little different than youres.
Old Jan 29, 2008 | 12:17 AM
YvettesSherpa's Avatar
When I had my K&N filter put on and FMF pipes put on they jetted it to much anyways so I had to redo it myself. The jets that came with the kit were a good enough mix for me to get the right ones for my bike..
Old Jan 29, 2008 | 11:21 AM
BZaj's Avatar
Actually, he's right. I di have to lower the jet size ( originally we went so big due to the fact that we were tuning it in when it was -55 outside) depending on the weather. Now i'm still one size bigger than what HMF sent, but still had to keep needle jet turned out. All in all, it's a different exhaust system and probubly will have different settings that go with it( also a different machine). I guess i would put the jets in that came with it and then decide to turn the main needle out a little at a time ( if needed) . Hopefully it helps.
Old Jan 29, 2008 | 01:22 PM
Yeah the best thing to do is put in the jets and see how she runs. Even after I had it jetted right I still has to raise my needle one notchto get enough fuel on the top end
Old Jan 29, 2008 | 02:55 PM
ScramblerXLE's Avatar
Your best bet is the JD Jet Kit JD JETTING Contact them and they can help you out with any questions and get you started in the right direction for jetting your 525.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
