Carb Help Please......
Man I cant figure this thing out..It's a brand new carb with about 100 miles on it and something is wrong..
Sometimes it won't get gas at all..and so I took off the float bowl and seems the floats were hanging up a little...so I blew it all out with air,then the floats moved all the way up and down without it getting hung up..I put it back together and now it was getting gas...But after running for a few min,wile runing gas started coming out the drain tube on the bottom of the carb even though the screw was tight,and now even when off If I turn on the fuel ****,gas will still come out the drain tube on the bottom of the carb..
Any one have any idea what can be going on here??And maybe steer me in the right direction on how to fix it?? Thanks..
I can't hardly remember this far back but, I had a similar problem back in the late 80's with a snowmobile. It was a sticking float. I know it is a pain but tear it apart again ( COMPLETELY ). clean everything, then let it sit overnight (apart). Put it back together and recheck everything again for cleanlyness. That is all I did. I say leave it set overnight to dry it out. I usuelly miss something ( dirt ) when it is wet. Hope this helps.
