Flickering lights
Old Jan 28, 2008 | 08:02 PM
Junior000's Avatar
Default Flickering lights
I have a 97 trx300FW. I went to run it a few weeks ago and the lights were flickering and dim. I put a new battery and there fine...but if I disconnect the battery while its running they do what they were doing, flickering and dim. Is that normal or should the alternator put enough out to keep the lights going? I dont want to take it out and lose lights as soon as it drains the battery..
Old Jan 29, 2008 | 08:37 AM
Junior000's Avatar
Anyone know if you diconnect the battery will the lights flicker??
Old Jan 29, 2008 | 09:56 AM
JeffinTD's Avatar
I would think at idle w/no battery getting dim might be normal... Do you have a volt meter?
Old Jan 29, 2008 | 12:22 PM
boostnm3's Avatar
Flickering when the battery is removed is normal. At idle your stator doesnt put out as many volts. When you rev it, the lights should get brighter without a battery. They get brighter because the stator puts out more volts. When the battery is connected the lights should be the same brightness all the time because its running off the 12 volt battery at all times. Hope this helps
Old Jan 29, 2008 | 05:27 PM
tlsmith's Avatar
ok, I have a qhick question. I own an 06 honda rancher and it seems that when Im idling, if I pull the brakes the lights dim...is that normal?
Old Jan 29, 2008 | 06:40 PM
angler's Avatar
I have a 2005 Rubicon and it does the same thing when I hit the brakes. I would say it is normal.
Old Jan 29, 2008 | 06:59 PM
kempre's Avatar
i have a 400ex and the lights flicker on it somtimes because the light switch is bad and their dim if its idle but the stator is fine
Old Jan 30, 2008 | 07:10 PM
Junior000's Avatar
With the battery didsconnected, they are dim and flicker. when you apply throttle they dim out more but get steady.. Voltmeter on the battery terminals with one disconnected while the bike is running should show what its chargeing at correct?
Old Jan 30, 2008 | 09:32 PM
JeffinTD's Avatar
With the battery hooked up, you should see a voltage increase when it's reved up, vs when it isn't running.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
