Yamoto 200cc
Old Jan 30, 2008 | 09:56 PM
Joey32's Avatar
Default Yamoto 200cc
I was wondering if anyone can help me. I just bought a used yamoto 200cc ATV and know nothing about them or engines for that matter.
1st question: Do these require a gas/oil mixture or just straight gas?
2nd question: If there is fuel leaking from the carburetor hose, how do I fix this?
Especially knowing that I know nothing about this stuff.
Please help!!!
Old Jan 30, 2008 | 10:08 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Joey32! [img]i/expressions/face-icon-small-smile.gif[/img]
Straight gas, no oil.
You either have something blocking the needle in your float bowl or you have a float that needs adjusting. You need to remove the float bowl to fix the problem. You need to take the carb off and take it apart. Its not that complicated but is intimidating the first time. After you remove the carb you need to take off the fuel bowl, remove both of the little brass jets. Pull the float pin and remove the float and needle. Blow all the little holes out with compressed air. put it back together and look at the float from the side. It should look level, if its not carefully bend the brass tab on the float until it is level.
Old Jan 30, 2008 | 10:21 PM
Joey32's Avatar
thanksmywifesquad. I appreciate it. I guess I will try it. Hope I do not break or lose anything. Do I have to take the whole thing apart or can I squeezein there to get to the carb
Old Jan 30, 2008 | 11:03 PM
KTM Patrol
Former Chinese POW!
Your welcome. On the 200 you should be able to get to the carb ok. Some times you need to remove the manifold and the carb to get enough clearance.
kbazzy
Sep 26, 2015 11:26 AM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
zach1106
Jul 31, 2015 01:55 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
