YAMAHA YZ80 QUSTION
Old Jan 31, 2008 | 08:06 PM
joshjines's Avatar
Default YAMAHA YZ80 QUSTION
I GET BACK TO MY HOUSE AND I CLEAN OUT THE EXUAST AND A BUNCH OF GAS OIL DRAIND OUT OF IT THIS IS THE 2ND TIME THIS HAPPEND?? I PUT IT IN 1ST GEAR DONT START 2ND GEAR DONT START 3RD GEAR FIRES RIGHT UP. SEEING AS I AM HAVING TROUBLE WITH MY SHIFTER I CANT SHIFT BACK DOWN TO 1ST OR SECOND FAST ENOUGH. BUT EVERY TIME I TRY IT IN 4TH OR HIGHER IT STARTS BUT FIRST OR SECOND IT DONT WHY???????????????
WHY??
THANKS JOSH JINES
Old Jan 31, 2008 | 08:29 PM
1smokin50's Avatar
Have you tried the Yamaha board yet??
Old Jan 31, 2008 | 09:49 PM
TxMagnum's Avatar
If it is smoking more than normal, it is the rings leaking fuel mix past and into the cylinder. I think the different ratio in the higher gears makes it easier to start with this stuff in the cylinder, like when you push start a car. it works better in third rather than first. just a guess.
Old Jan 31, 2008 | 09:51 PM
itch's Avatar
low compression or clogged pilot jet, maybe both
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
