2007 arctic cat 500
Old Jan 31, 2008 | 09:50 PM
ADAMSQUAD's Avatar
Default 2007 arctic cat 500
i have about 650kms on it now, do i need to adjust anything on it? it runs fine but i have heard of people adjusting their valves. do i need to do that?
Old Feb 1, 2008 | 05:51 PM
mudslinginfool's Avatar
Does it in the Mud!
manual says to but its up to you. i did, at 100 miles then 1000 miles and again at 2500 miles. thats the only thing i have had adjusted.
Old Feb 1, 2008 | 07:05 PM
ADAMSQUAD's Avatar
would i be losing power by not doing it?
Old Feb 2, 2008 | 10:44 PM
Does it in the Mud!
in time, you will lose power and probably waste fuel. not alot ,but you will b/c the vavles arent closing or opening at the right time. thats why you get them adjusted. for example, on my dodge ram (deisel), for $120 i had my valves adjusted and now i get 650 mile per tank of fuel. i used to get about 550-600 miles per tank. of course thats a truck not a bike but you get the point.
Old Feb 2, 2008 | 11:00 PM
HeftyLefty's Avatar
Yes, it would also be harder to start. With 650kms, you may looking at a valve job, if yours are warped from being out of adjustment. You may have to replace the head too, if the valve seats have been screwed up.
9 times out of 10 its the exhaust valves that screw up. They don't open all the way, over time the hot gases warp the valve, they don't seal properly-accelerating the warping-and the valve beats up the seat in the head. Eventually the engine just won't run, or the valve breaks(dropping a valve), with the pieces bouncing around the cylinder and poking holes in the piston before the engine stops .
Were I you, I'd pull the head off and look.
Old Feb 4, 2008 | 02:09 PM
ADAMSQUAD's Avatar
so you guys are saying i better get it done right away? before it screws something up. right now it still runs and starts perfect. is it expensive?
Old Feb 4, 2008 | 02:41 PM
ADAMSQUAD's Avatar
i for got to ask also, is this something i can do myself? if so, how do i go by doing it?
Old Feb 4, 2008 | 06:27 PM
Does it in the Mud!
depends on what you dealers hourly rate is. mine is $85 an hr. so it cost $85. you can do it your self yes, but if your not mechanicly inclined, id take it to the dealer. it could turn into more of a job if youve never done it or seen it done. or you can screw up the whole thing. as far how to do it, to much to explain on here for me, im not a fast typer.
Old Feb 4, 2008 | 08:10 PM
ADAMSQUAD's Avatar
so this is something i have to get done right away?
Old Feb 4, 2008 | 09:00 PM
Does it in the Mud!
well you have 650 km or (400 miles) on your bike so i would do it within the next few rides. you should do it at the first 100 miles but not everyone does. to prevent damage now or in the future, just get it done before 1000 km.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
