Pull Start
Old Feb 5, 2008 | 10:09 AM
opsman56's Avatar
Default Pull Start
Can you add a pull start to a 02 700?
THX
Old Feb 5, 2008 | 11:03 AM
JAMIEZ71's Avatar
Default Pull Start
I know the Military version of the sportsman has a pull start on it. I'm not sure if you can buy that part extra or not. Someone out there probably makes something for it but let me say it would be a job to pull start one.
Old Feb 5, 2008 | 11:14 AM
TLC's Avatar
TLC
Default Pull Start
Don't bother unless the 700 has a decompression. It took two of us to pulling on the rope to turn over a 660 Grizzly. Some people go the other way and remove them on Polaris. The pull handle is the only thing that stops mud and water from going into the recoil housing. Once mud and water get in (And it will) its on your $350 stator,pulse coil and flywheel. Its a bad set up to say the least.
Old Feb 5, 2008 | 11:27 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
Default Pull Start
Yup, these effers PULL HARD
Old Feb 5, 2008 | 12:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Pull Start
thats why these bigger bikes have bigger batteries.
Old Feb 5, 2008 | 01:46 PM
JAMIEZ71's Avatar
Default Pull Start
I totally agree with all that was said above. My 500 h.o. could be a bear to pull and I had to drain mud and water more than once from the recoil area due to water slipping in around the pull handle. Let me say that in the winter it tends to cause your starter bendix to freeze up if it gets wet in the recoil cover. Just keep your battery good and charged or if a jump is needed on the trails cut up your winch power leads if need be to get you out of the woods.
Old Feb 5, 2008 | 02:41 PM
opsman56's Avatar
Default Pull Start
Great info.....I was curious since my old 650 Kaw Par had one and was pretty
easy.
Thanks Again....I guess this ol' 50 year old rookie will learn a few things here.
Thanks Anthony
Old Feb 5, 2008 | 07:06 PM
duffus's Avatar
Default Pull Start
i have an MV-- and it is HARD to pull and has a compression release. However, if the battery is dead dead-- it won't even start and it is a carb-- the newer electrical system (02 700 included) means you'll have to pull start until the battery has enough charge to fire the ignition-- well.. that doesn't happen with a dead dead battery.. .if it is weak, it will work.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
