awd 4x4 help
Old Feb 5, 2008 | 01:29 PM
matt1969's Avatar
Default awd 4x4 help
i have a 1999 sportsman 500.the speedometer is bad i really dont want to buy ia new one.is there a way to rewire the hubs to make the awd work?any info would be great.
Old Feb 5, 2008 | 01:43 PM
JAMIEZ71's Avatar
Your speedometer shouldn't have anything to do with the awd. My buddy busted his cluster bad during a roll over and his worked fine. He just had to feel to see what gear he was in and so on. Check on Bikebandit.com though for a replacement if you decide to get one. Sometimes they are quite cheap on parts.
Old Feb 5, 2008 | 02:35 PM
1greenhornet's Avatar
Matt1969,
I did a bunch of research last summer cuz my speedo was bad and read a thread that talked about grounding the brown wire that goes to each of the hubs. I think if you do that you will still be able to use the 2X4 / 4x4 switch. I don't remember all the details but if you do a search you should be able to find everything you need. The other option is to check ebay for a used Speedo; the model your looking for goes for around $150.
Good luck.
GH
