Best Upgrades or Mods
Old Feb 6, 2008 | 11:34 AM
banwartm's Avatar
Default Best Upgrades or Mods
I'll take any info you want to share. I'd also like to know what the outcome was or what outcome you expect from the changes. If you've done something I'd like your input on how it turned out and if you'd recomend it for others. Any photos of your mods would be good to see too.
Old Feb 6, 2008 | 11:55 AM
LT80's Avatar
LT80 Expert
What machines?
Old Feb 6, 2008 | 12:01 PM
banwartm's Avatar
Any of the smaller quads. Say up to 125cc or so.
Old Feb 7, 2008 | 11:49 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
On my Jetmoto 125 I have the aftermarket exhaust, the mikuni carb with the foam air filter. Got better power and it now sounds like a quad not a lawn mower. Not loud at all but much stronger sounding.
Old Feb 7, 2008 | 12:20 PM
Sawyer's Avatar
Well on my 110cc quad I had issues with the engine rattling out of the motor mounts. I tried different grade 8 bolts, made a new bushing, built up the ears on the the lower mount with the mig....but still that darn thing would get loose.
I have a 90 atv and it is bolted to the frame on the bottm of the engine. So thats what I did I took a 4" wide by 1/4" thick piece of flat iron, drilled 4 holes in it so it would bolt right up to the bottom of the engine then welded it to the frame across the bottom. Problem solved its been good ever since. I have since noticed on the newer 110's they have gone to this mounting system where its bolted to the bottom of the engine.
Old Feb 7, 2008 | 12:28 PM
Sawyer's Avatar
On the Jet 150 I noticed the bushings in the front upper shock mounts were not quite wide enough. So if you tightened up the bolt you would bend the ears and if it you left it loose in time I imagine it would get slopped out more. So I just added a washer (see my pics) to take up the clearance.
Old Feb 7, 2008 | 01:25 PM
KTM Patrol
Former Chinese POW!
<div class="FTQUOTE"><begin quote>Originally posted by: Sawyer
I have a 90 atv and it is bolted to the frame on the bottm of the engine. So thats what I did I took a 4" wide by 1/4" thick piece of flat iron, drilled 4 holes in it so it would bolt right up to the bottom of the engine then welded it to the frame across the bottom. Problem solved its been good ever since. I have since noticed on the newer 110's they have gone to this mounting system where its bolted to the bottom of the engine.</end quote></div>
Thanks for reminding me, I need to do this to my 125. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 7, 2008 | 11:47 PM
balanis03's Avatar
Ok i know this is for 125cc and smaller quads but i was wondering i have a 250cc Jetmoto and would like to do some mods to it to make it quieter and a little more power? Which type of aftermarket exhaust would fit on a Jet. also what advantages would i have on adding a different carb and what size and brand would fit for my bike?
Old Feb 8, 2008 | 11:20 AM
banwartm's Avatar
Thats good info to know about the motor mounts. I know mine is bolted to the frame, but I'm sure I haven't found all the bolts to tighten them up myself yet. I've noticed the gas tank on our 110 has a rattle to it. I need to get under there and figure out how to tighten that up. Looks like it is a machine screw that is used to fasten it to the frame front and back of the tank. Maybe some locktite will do the trick?
Has anybody put wheel spacers on these atvs? How hard was it to figure out the right parts to get, and did you get the stability and turning radius you wanted? Doesn't look expensive, but I read something where you might have to notch an inch out of the fron fenders to allow for the new placement of the front tires while turning. Any experience in that?
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
