Issue with front sprocket
Old Feb 6, 2008 | 09:44 PM
lethalmethods's Avatar
Default Issue with front sprocket
My chain came off and wedged up between the front sprocket and chain guard (they were old). I got a new chain and sprockets. Now the front sprocket wiggles a little on the output shaft. It stays on the splines ok in a rotating motion, but i can wiggle it front and back (to and form the engine). Has this happened to anyone? Does anyone have any ideas for fixes?
Old Feb 6, 2008 | 11:47 PM
YvettesSherpa's Avatar
if it was me i would replace it. It sounds like it is worn out too much to tighten down all the way, but your output shaft my be worn now too....
Old Feb 7, 2008 | 08:28 AM
The sprockets and chain are new. So it sounds like the output shaft. I assume this is a tough/expensive job to do.... :-(
Old Feb 7, 2008 | 09:23 AM
zooooom's Avatar
The front sprocket will have some movement in it because it "floats" on the splines. Only thing that holds it on is the little plate on the end. All the front sprockets I've seen do this.
Old Feb 7, 2008 | 10:09 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Does the shaft itself have play in it, or is it just the sprocket on the shaft that has play? I hope you are running a case saver!
Old Feb 7, 2008 | 10:16 AM
scootergptx's Avatar
Supersock
Hired Gun!
I second the case saver. The few dollars they cost are well worth the investment.
Old Feb 7, 2008 | 04:55 PM
Both the shaft has a little bit of play and the sprocket. I just ordered a case saver. Thanks for the heads up. Probably should invest in some good ankle savers (boots) too.
Old Feb 7, 2008 | 09:46 PM
zooooom's Avatar
I've got a busted case on a 250x in my garage right now. The factory should've put a better guard on them.
VRRRRT
Jun 27, 2015 09:38 AM
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
rhino99
Oct 2, 2000 02:44 PM
dosthoff
Jan 3, 2000 10:04 PM
