Need Help Quick Guys
Old Feb 10, 2008 | 03:28 AM
rockman250's Avatar
Default Need Help Quick Guys
Just need to know will the 2004 warrior motor fit into a 1997 or 1998 warrior frame? Will it be a direct swap?
Old Feb 10, 2008 | 11:23 AM
Raptor450's Avatar
It is a direct swap. From '90-04 they were all the same. The wiring harness is different and the stator changed, so you will probably need the stator and the wiring harness from the '04, or keep the '97 stator and wiring harness and install it on the '04 motor.
Old Feb 10, 2008 | 02:29 PM
rockman250's Avatar
OK, i was thinking that was the case, but wasn't sure. I have a 98 and it broke the rod completely off, and fell in the crank and basically made a mess of the bottom end. I can pick up an 04 motor for less than what a crank will cost me, so I think that will be the way to go. So I will have the stator and the wiring harness from the 98, but only the motor from the 04 no wring harness. Seems like a reasonably easy swap. Oh and Thanks for the quick reply.
Old Feb 21, 2008 | 09:00 PM
rockman250's Avatar
OK, now I have another question, motor came in and i went to swap the stators and the plugs are identical, and so is the wiring color coding, so is the motor not an 04? How do I tell or are the stators still different?
Old Feb 21, 2008 | 11:08 PM
Raptor450's Avatar
Should be the same then. I don't know exactly what years were different. Maybe the early 90's are different from the later models.
Old Feb 21, 2008 | 11:12 PM
beefy46172's Avatar
Loves To Ride!
If the motor you got was an '04, and yours was a '98, then the harnesses should've been identical I do believe.
Old Feb 22, 2008 | 01:52 AM
rockman250's Avatar
OK, ill move forward with the swap then, it will be easier than i thought. Thanks.
bzdok1234
30
Feb 23, 2016 01:55 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Robinhood
Jul 13, 2015 09:13 PM
black_thunder
Jul 9, 2015 05:58 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
