Blaster Oil Block Off Kit?
Old Feb 10, 2008 | 11:11 AM
04BlasterRider's Avatar
Default Blaster Oil Block Off Kit?
I have a 2004 blaster with not too many hours of the machine, but i was wondering if i should put the oil block off kit on it since i hear of the oil pump failing. Any opinions would be appreciated. Thanks
Old Feb 10, 2008 | 01:11 PM
qsportgoat's Avatar
it seems this is a split subject. many people say the pumps are no good and must be blocked off and others will say the opposite. the gears on the pump are plastic which sounds weak but if you think about it they are lubed and the pump does not require much to turn it. i do know people who still have the original pump on there old blaster and its fine. myself i blocked mine off.i know i can mix my own gas/oil correctly,plus i can tailor it to my own needs. plus i wanted the weight savings of the tank and pump,which is about 6 lbs (full). so i guess im saying if you feel comfy to mix your own at 32:1. and want the weight savings go for it.but others wise i think the pumps are reliable. good luck
Old Feb 10, 2008 | 02:45 PM
Hey thanks for the reply i will have to think bout what i want to do for sure but i would rather just block it off to be safe
ReconBayou
Oct 31, 2022 05:37 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
