How to reset Belt Warning Light on AC 650 V2
Old Feb 10, 2008 | 03:26 PM
mirlkman's Avatar
Default How to reset Belt Warning Light on AC 650 V2
What is the proper procedure?
Old Feb 11, 2008 | 02:24 PM
62Handler's Avatar
Got this off the kawasaki thread, it worked when i had my Brute Force, should be the same for your V2. not a bad idea to keep the procedure with you in the quad somewhere.
Wringer says:
1) remove seat, unplug black and grey 4-pin connectors
2) swap plugs, grey to black and black to grey
3) turn on ignition switch, belt light should be flashing quickly
4) disconnect 2-pin belt switch above torque converter cover, belt light should be flashing slowly
5) let flash for at least 5 seconds
6) turn off ignition switch
7) reconnect 4-pin connectors black to black and grey to grey, reconnect 2-pin belt switch
8) turn on ignition switch to confirm belt light is out
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
