1996 scrambler 400, waterpump
Old Feb 13, 2008 | 05:25 PM
jet42485's Avatar
Default 1996 scrambler 400, waterpump
i have a 1996 polaris scrambler 400,it over heats and im thinging its the water pump,is there a way to test the pump?
Old Feb 13, 2008 | 06:52 PM
itch's Avatar
when the motor is cold remove the radiator cap and start it ,see if the water is moving thru it or if its just still also look for bubbles in the system while running which could indicate a warped head or leaking head gasket
Old Feb 14, 2008 | 08:22 AM
Woodchips182's Avatar
Have you checked to see if the fan comes on? The thermal fan switch went on my 96 Sport 400 not allowing the fan to come on and leading to overheating. I wired the fan to a switch to correct the problem.
Old Apr 25, 2008 | 08:26 PM
EPeterson's Avatar
I have the same problem how did you wire the fan to come on with the switch ? did you connect it to the battery? what wires did you connect to? some instruction or pictures would be great.
thanks
Old Apr 26, 2008 | 09:16 AM
Ujoint's Avatar
It's actually very simple - locate your thermal switch on the radiator, unplug the wires (there are 2 wires to the thermal switch - 1 comes from the ignition switch power, the other goes to the radiator fan) - splice in a heavy duty toggle switch between the 2 wires you unplugged from the thermal switch.
Old Apr 26, 2008 | 05:47 PM
Ujoint is right. It's a pretty simple fix. That's just what I did and for the last year I've had no overheating problems.
Old Apr 27, 2008 | 12:35 AM
sprinter10's Avatar
thermostat sticking not alowing water to flow threw would show the same as a bad water pump.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
chewy78
Sep 8, 2015 10:37 AM
