blaster problem
Old Feb 17, 2008 | 01:12 PM
dirtmaster4's Avatar
Default blaster problem
I have a 01 blaster and rebuilt everything on it and when i started it it runs in reverse any ideas
Old Feb 17, 2008 | 05:19 PM
TomM's Avatar
Well thats an interesting one. Exactly what is "everything"? You could probably cuase that by putting some gears in wrong. Theoretically a 2 stroke motor could run backwards. I think its even been used for reverse on a quad. However if the electronics on a Blaster are the same as all the 2 stroke quads Ive worked on it would run terrible if it did. Therefore if the motor runs good I would suspect gears are in the wrong place.
Old Feb 18, 2008 | 12:37 PM
Doctorturbo's Avatar
GOT BOOST!
I think I remember a few years back this happened to someone on this forum. I think the guy swapped some wiring by accident on the starter, he switched it back and it fixed the problem. You might do a search for it on here.
Two strokes run great backwards. They don't care which way they run.
Old Feb 18, 2008 | 03:35 PM
TomM's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Doctorturbo
Two strokes run great backwards. They don't care which way they run.</end quote></div>
The mechanical parts may not care but the electronics will. If the crankshaft spins backward so will the flywheel/magneto which would cause the sparkplug to fire after TDC instead of before which would not be too good for performance.
Old Feb 18, 2008 | 03:39 PM
TomM's Avatar
Also Blasters use a kick start no electric starter.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
