Raptor Starter problem HELP.....
Old Feb 18, 2008 | 10:50 PM
brandglend's Avatar
Default Raptor Starter problem HELP.....
I have just recently had a problem with the starter and my Raptor, it will sometimes just spin free and after a few tries it with kick in and turn the motor or sometimes work just fine. I was wondering if any others have had this happen????Thanks..
Old Feb 19, 2008 | 05:00 AM
viper5's Avatar
That's a common problem on the 660's and it's caused by a faulty starter clutch. It's under $200.00 for a new starter clutch and hub. If you don't fix it it will stop starting someday (soon) and thay aren't much fun the catch in gear[img]i/expressions/face-icon-small-mad.gif[/img]
Old Feb 19, 2008 | 11:38 PM
brandglend's Avatar
By starter cluch you mean the one way bearing? and how hard is it to change?
Old Feb 20, 2008 | 01:03 AM
viper5's Avatar
Yes the starter clutch and the one way bearing are the same thing.(it's called the one way starter clutch in the yamaha service manual) It's located under the left side cover (left as you sit on the quad) the hardest part of the job is getting the magneto rotor off of the shaft, for this you will need a puller. After that the rest is cake.
The starter clutch bolts tighten to 11 ft lb and the magneto rotor nut to 110 ft lb side cover bolts to 7.2 ft lb
Hope this helps, if you need any other info let me know
toonces
Oct 16, 2019 12:11 PM
AtvManiac78
Jul 11, 2015 03:20 AM
tweeder
Jul 5, 2015 01:57 PM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
