Yamaha Warrior: oil in air box
Old Feb 19, 2008 | 03:25 PM
bigjake34452's Avatar
Default Yamaha Warrior: oil in air box
my friend just bought a 96 warrior, after riding it today, we noticed fresh oil in and a little on top of the air box....what could this be? it was not flipped.
Old Feb 19, 2008 | 04:55 PM
racerex1's Avatar
You sure that it's not oil from the foam air filter? The stock air filter on the Warrior has a foam element around the mesh filter that should be coated with oil to help it collect dust. If you look under the air box, you should actually see a clear cap that collects any oil that may drain off of the filter.
Old Feb 19, 2008 | 08:07 PM
recon99's Avatar
Either filter oil, or you have oil coming in through the crankcase breather. Usually when oil is coming through the breather it's because the oil is overfilled.
Old Feb 19, 2008 | 09:25 PM
TLC's Avatar
TLC
Up and down steep hill riding can also do it, not just a roll over.
Old Feb 19, 2008 | 09:56 PM
recon99's Avatar
I've never seen oil in my airbox from riding up a hill... only time I ever saw it in the 4 years i've had my warrior was when it was just from over-oiling the filter.
Old Feb 19, 2008 | 10:20 PM
thanks guys, the oil was WAY overfilled
Old Feb 19, 2008 | 10:24 PM
recon99's Avatar
That'll do it.
Old Nov 12, 2008 | 08:28 AM
djm1k0's Avatar
Default Yamaha Warrior: oil in air box"></title><script src=
<div class="FTQUOTE"><begin quote>Originally posted by: recon99
I've never seen oil in my airbox from riding up a hill... only time I ever saw it in the 4 years i've had my warrior was when it was just from over-oiling the filter.</end quote></div>
How much oil does the warrior take to fill when changing the oil ?
Old Nov 12, 2008 | 06:11 PM
warriorslayers's Avatar
Just and oil change is 2.53 Qt's
Oil Change and filter change 2.64
hope that helps and remember it's ALWAYS best to change the filter when changing oil it very inexpensive
buddieboy
Dec 9, 2016 05:50 PM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
black_thunder
Sep 22, 2015 07:59 PM
