Grizzly 700 fuel Programmer
On my raptor 700 I have the Power Commander III. It gives you the ability to add or take away fuel at every throttle position and at what ever RPM range you want. I believe the Dobeck will not let you "fine tune" like the PCIII will. If your not going to do internal engine mods then the dobeck would be fine for you.
i know my brother has a raptor and i seen the way the powercommander works but on there web site they only have like 3 or 4 maps for the grizzly where can i get more maps.
The best way to get any bike set up exact is to take it to a dyno shop. There could be a 100 maps on there site, some will be close but every quad is different. I found this out trying different maps for mine. I took mine to a dyno shop and it runs good now. I also installed a wideband o2 sensor now I can see real time air/fuel ratio while I ride. If your going to buy a PCIII go to www.fuelmoto.com No one can touch Jamie's price. He will preload a map for you for your setup. It should get you close. Hope this helps.
