Grizzly 700 fuel Programmer
Old Feb 23, 2008 | 11:33 AM
kingfish0130's Avatar
Default Grizzly 700 fuel Programmer
I have a grizzly 700 with a hmf utilty series, which is the best programmer out of the HMF, Powercomander, Dobeck.
Old Feb 24, 2008 | 11:28 AM
lerea3's Avatar
On my raptor 700 I have the Power Commander III. It gives you the ability to add or take away fuel at every throttle position and at what ever RPM range you want. I believe the Dobeck will not let you "fine tune" like the PCIII will. If your not going to do internal engine mods then the dobeck would be fine for you.
Old Feb 24, 2008 | 11:44 AM
i know my brother has a raptor and i seen the way the powercommander works but on there web site they only have like 3 or 4 maps for the grizzly where can i get more maps.
Old Feb 24, 2008 | 11:53 AM
lerea3's Avatar
The best way to get any bike set up exact is to take it to a dyno shop. There could be a 100 maps on there site, some will be close but every quad is different. I found this out trying different maps for mine. I took mine to a dyno shop and it runs good now. I also installed a wideband o2 sensor now I can see real time air/fuel ratio while I ride. If your going to buy a PCIII go to www.fuelmoto.com No one can touch Jamie's price. He will preload a map for you for your setup. It should get you close. Hope this helps.
Old Feb 24, 2008 | 12:08 PM
All right ill check it out thanks for the info
greg74
Sep 10, 2019 03:03 PM
merryman
Sep 6, 2015 10:20 AM
1000gade
Aug 19, 2015 07:10 PM
Jul 28, 2015 12:12 PM
Aitch
Jul 21, 2015 09:40 PM
