NO spark
Old Feb 25, 2008 | 11:23 AM
the bayou's Avatar
Default NO spark
I ahve a 1992 polaris 350L 2 stroke Last night they guys and I were going to go out for a ride and it was Icy here in missouri so....of course I let it warm up. The quad was covered in a thin layer of ice. but I started it and let it warm up we went back inside and about 5 min later we heard it die. Went back out and it wouldn't start so we pulled the plug and checked it for spark.......NO SPARK.... Does anyone have any Idea what it could be I spoke with polaris in town and they said they have never had a coil go out in one so I am stuck as to what it could be? Oh and one more thing I also checked the stator by following the Clymers manual and testing the red/yellow and yellow wire with an ohmeter it seems to be fine any help would be great
Old Feb 25, 2008 | 11:50 AM
the bayou's Avatar
Default NO spark
Any one??
Old Feb 25, 2008 | 01:37 PM
furnaceman's Avatar
Default NO spark
just a thought I had the same thing happen once it was a bad flywheel the magnet broke loose. also check your spark plug wire. You should get a service manual to help you out with the electrical end of it.
Old Feb 25, 2008 | 04:27 PM
the bayou's Avatar
Default NO spark
thnaks I will check out the flywheel is there a way to put the magnet back on?
Old Feb 25, 2008 | 04:52 PM
sprinter10's Avatar
Default NO spark
could the plug have fowled if you let them idle sometimes it will fowlout at leaste on mine anyway try a new plug.
Old Feb 25, 2008 | 04:54 PM
the bayou's Avatar
Default NO spark
My first thoughts.....but I even stuck a screwdriver in the spark wire and held hoping(not really) that I would get shocked and nothing So i am trying to dig deeper
Old Feb 25, 2008 | 04:58 PM
sprinter10's Avatar
Default NO spark
o ok it could be the coil but i don't think that would just stop like that i would check the flywheel like furnaceman said idk i never had a problem like this i had every other problem thow haha.
Old Feb 25, 2008 | 05:00 PM
the bayou's Avatar
Default NO spark
I guess I will pull the flywheel this weekend and see...... Will i need a fly wheel puller and if so where can I aquire one?
Old Feb 25, 2008 | 05:13 PM
sprinter10's Avatar
Default NO spark
um odk if you need to pull the flywheel or not but if you do you will need one you can get ehm on the internet or polaris dealer. http://www.google.com/products...l+puller&um=1&ie=UTF-8or here is a sighthttp://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=3&catID=24&pro ductID=217
Old Feb 25, 2008 | 05:15 PM
the bayou's Avatar
Default NO spark
I will let you guys know what I find....We cna just hope it is something simple......... HA Right..........
