2007 X2 500 EFI Brakes
Old Feb 26, 2008 | 04:34 PM
OIown12's Avatar
Default 2007 X2 500 EFI Brakes
My 07 500 X2 has a brake chirp coming from the right front. Only happens at around 5-10 mph. [img]i/expressions/face-icon-small-confused.gif[/img] I pulled the tire off yesterday and noticed that the rotor was rubbing in one small spot. Here is the mystery. The pads aren't worn at all. Could the rotor be warped? Any thoughts or ideas? Brake fluid is AOK.
Old Feb 26, 2008 | 04:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
somethings not right as the pads should be hitting al the time and evenly across for sure. any way to turn the assembly and watch to see if the rotor would be warped or bent?
Old Feb 26, 2008 | 05:12 PM
OIown12's Avatar
Yea, I did. Didn't see anything noticable other than the spot were the rotor was rubbing.
Old Feb 26, 2008 | 07:48 PM
brutus450's Avatar
my right front chirps at low speeds too - i have never found a rotor to be perfect "square". All rotors i have seen have a small warp or high spot. I just put brand new rotors and pads on my truck and my left front on my truck chirps at low speed. Lift any vehicle off the ground and spin the tires I bet you will not find that all spin freely and evenly.
It is annoying I agree but nothing to worry about
take the pads off and put some anti squeel back lube on all the contact points on the back of them - it should help.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
