kazuma 110 carb problems
Old Feb 26, 2008 | 07:53 PM
30-30's Avatar
Default kazuma 110 carb problems
I just bought a used 110 kazuma falcon. I'm havig carb problems I have tried to adjust mixture scew and idle screw as well as the throttle cable. It is really hard to get started but when i finally did i tried turning the mix screw all the way in and then backed out to full turns.I then adjusted the idle screw till it idles good. when i put it in gear it either wants to stall or it has very weak power. when i try to turn up idle while its in 1st gear it will some what run, but when i go back to nuetral it revs real high. I also tried to take the throttle cable out and rasie the eclip on the needle. this brings me to my next problem when i put the needle back together does the needle go back in first then the curly shaped metal piece go on top of the eclip( It looks like its maybe there to keep it in place) and then the cable and pring are attathed? this is currntally how i have it in place. and i'm still having the same problems. Any sugestions will be great.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
