Hondamatic
Old Feb 27, 2008 | 06:09 PM
saby5757's Avatar
Default Hondamatic
Have a quick question for any Honda mechanics....
I have the opportunity to buy a Hondamatic....cheap.... however, its partially taken apart..... I wasn't really aware that they could be taken apart, but i guess they are.
So what I was wondering it there was a diagram to put them back together and if they can be? Because I thought they were sealed units?
Thanks
Saby575
Old Feb 27, 2008 | 11:11 PM
cluby's Avatar
Default Hondamatic
The service manual doesn't tell you how to take them apart or test them sooo. I wouldn't buy one that was taken apart. Keep watch on ebay they seem to pop up on there quite often. All years will work.
Old Feb 27, 2008 | 11:48 PM
Gimpster's Avatar
Default Hondamatic
If it is for a 400AT I could help you out with one
Cluby, haven't heard from you in a while, I sent you a PM for a stupid question that has slipped my mind.
Thanks
----- Gimpster -----
Old Feb 28, 2008 | 01:13 AM
saby5757's Avatar
Default Hondamatic
Well actually its for a Rubicon.....
How much different are the two Hondamatics? Rancher AT vs Rubicon
Thanks
Old Feb 28, 2008 | 07:25 AM
HondaMechanic's Avatar
Default Hondamatic
We've had a few apart ... They can be taken apart but Honda doesn't make/sell replacement parts .. We've changed dozens of Hydrostatic transmissions in Rubicons since 2001 and a LOT were still good but Honda Canada wanted them changed as an assy. even tho the oil pump was the problem (low pressure) .. I wish now that I would have labeled the good pumps ..
I will post some pictures of a dis-assembled Hydrostatic unit as soon as I find the pics ..
Old Feb 28, 2008 | 07:52 AM
Default Hondamatic
Old Feb 28, 2008 | 09:25 AM
cluby's Avatar
Default Hondamatic
Ya Gimpster, I have been away from this site for awhile. Just needed a break, you know you give good tech and some people won't listen.
Good pics of HFT unit disasembled there. I took a bad one apart once got so far then quit.
My only question would be once you have it apart what other than a bearing would you replace?
I myself have done over 10 from 2001, mostly cause of low oil pressure. Honda wanted use to reuse the HFT and just put in a oil pump, but once back together it grind or make noise. Then back all the way apart to rnr the HFT. I think not we just told them it wouldn't pass the bench test. So I had a pile of questionable HFT units. I still have one left for a 500. Just put one in a friend of mine, told him great if it works, if not get out the checkbook 1400 bucks over the counter.
shimanok2
Jan 29, 2016 07:37 PM
fourtraxhonda300
Apr 15, 2010 09:09 PM
IOWA01RUBI
Nov 11, 2009 05:37 PM
RedGoblin
Jul 3, 2005 09:54 AM
mouser383
Mar 26, 2004 11:54 PM
