clean carb leaking gas
Often plastic floats can't be adjusted and should be replaced if the float level is wrong. The float level on these doesn't seem to get messed up very often, though.
Be sure to take a real close look at the float valve, and the float valve seat. If there's a step or groove worn into the cone part of the float valve, it's shot. Also it doesn't take much of a piece of debris in there to cause the float valve to leak.
