clean carb leaking gas
Old Feb 27, 2008 | 06:29 PM
go-hard-or-go-home's Avatar
Default clean carb leaking gas
gota nother 400ex leaking gas outa the carb?
the floats are made of plastic so you cant adjust them. anyone know how to fix this problem?:
Old Feb 27, 2008 | 06:36 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Are you saying it started after you cleaned the carb? If so I'd take it apart and put some new gaskets on it.
Old Feb 28, 2008 | 07:42 PM
its leaking out the overflow. not any seals. yes it runs but funny.
Old Feb 28, 2008 | 07:59 PM
JeffinTD's Avatar
Often plastic floats can't be adjusted and should be replaced if the float level is wrong. The float level on these doesn't seem to get messed up very often, though.
Be sure to take a real close look at the float valve, and the float valve seat. If there's a step or groove worn into the cone part of the float valve, it's shot. Also it doesn't take much of a piece of debris in there to cause the float valve to leak.
Old Feb 28, 2008 | 10:42 PM
hey thanks everyone!!! try it out tomorrow.
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
honda71
Jul 8, 2015 02:13 AM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
