coffee lookin oil
Old Feb 28, 2008 | 09:43 PM
rhonda350's Avatar
Default coffee lookin oil
today i helped my friend change his oil because it his first time and when i drained the oil it looked like coffee and the oil filter had lots of metal shaveings on it
i was planning to go show the oil filter to honda and see wat they will do and say
wat do u think i should do
Old Feb 28, 2008 | 10:52 PM
sac7000's Avatar
Need more info and photos
Old Feb 28, 2008 | 11:04 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Are you saying this was the original oil that it came with??? How many hours did he go before the oil change (or since the last oil change)???
Check the shavings to see if they are magnetic. If so, they are steel, if not they may be aluminum or sometimes clutch fibers.
Old Feb 28, 2008 | 11:32 PM
rhonda350's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
Check the shavings to see if they are magnetic. If so, they are steel, if not they may be aluminum or sometimes clutch fibers.</end quote></div>
yes it was the original oil that came with it the bike is brand new . the bike had 10 hours on it
Old Feb 28, 2008 | 11:43 PM
JimVT's Avatar
you may see a few fines in the first oil change. Keep a sample but you should be ok. What kind of break in did he do?
My rhino had off color oil when I picked it up.I made them change it . My sample showed water in it. The only thing we could think of was moisture in the water from setting in our damp pacific weather.
Old Feb 29, 2008 | 08:34 AM
action450s's Avatar
IF you have oil that is milky (say coffee with cream in it) then you have water in the oil, either you have a seal letting water in, or the bike was driven in deep enough water to get alot in the airbox which then went into the crank case. If the bike is under warranty send it in to the dealer with a sample of the oil you took out.
Old Mar 3, 2008 | 11:47 PM
rhonda350's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: action450s
IF you have oil that is milky (say coffee with cream in it) then you have water in the oil, either you have a seal letting water in, or the bike was driven in deep enough water to get alot in the airbox which then went into the crank case. If the bike is under warranty send it in to the dealer with a sample of the oil you took out.</end quote></div>
you will not belive this we brought the oil and oil filter to honda and they looked at it and said to bring the bike in so we did and u know wat happen they gave my friend a brand new bike they dident even tell us the problem with the other one
Old Mar 4, 2008 | 01:16 AM
JeffinTD's Avatar
You know, I seem to recall a similar thread a while back...
Old Mar 4, 2008 | 08:34 PM
rhonda350's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JeffinTD
You know, I seem to recall a similar thread a while back...</end quote></div>
yeah i know what ur talkin about and the people at honda really told me that the bike was a lemon and there were going to give my friend a new bike
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
WILDERP
Feb 26, 2001 07:01 PM
Mudskipper
Feb 14, 2001 04:26 PM
