BLASTER QUESTIONS
WE JUST FOUND A 95 BLASTER GREAT CONDITION FOR MY 12 YEAR OLD NEPHEW. FIRST QUESTION HOW MUCH CAN YOU SLOW IT DOWN USING THE THROTTLE ADJUSTER HAS ANYBODY DONE IT. ALOT OF COMMENTS ABOUT PLUGS IN OTHER POSTS WHATS THE BEST FOR THIS QUAD. QUES. ON SHUTTING DOWN THE OIL INJECTION IS IT BETTER TO DO, HOW WOULD YOU KNOW IF THERE IS A PROBLEM WITH THE INJECTION SYSTEM AND CANT YOU MAINTAIN IT . THANKS IF YOUR CHECKING IN ALEX(NEPHEW) HAVE FUN
2000 HONDA 300EX
FMF PRO CORE 4-2SA
K&N JET KIT AND FILTER
2000 HONDA 300EX
FMF PRO CORE 4-2SA
I would suggest taking off the oil injector. If you dont pay attention to it it could ruin your engine before you know it. It isn't hard to do you just buy a kit and install it.I dont know much about trying to make it go slow though cause i need all the speed i can get!
I agree with HondaManMyers. Taking off the injection is a must whether it works or not. Take the extra 5 minutes and 5 dollars and mix your gas. It took me 2 engine rebuilds to take the hint. Don't make the mistake I did.
Leave the oil injection on, unless you plan on racing it or something it will work just fine. Had an 89 that always had the oil inj hooked up and still on its original stock top end, with around 135-140lbs of compression. Also pre-mixing is a hassle, alot easier to just pull up to the pumps..
The throttle limiter is nice to slow it down, but it has one fault. If you need more power to get out of trouble, it's not there anymore! Also I do a lot of slow woods riding on mine and I have never ever fouled a plug! I also do not use the injection system. It's junk. I premix at 32 to 1 and have never had a problem. Just be sure to use a quality 2 stroke oil, not $0.99 walmart special. I use Klotz Techniplate or even Yamalube is ok. Ride on!
i`m gonna have to agree with timewass yank the injector and run klotz at 32:1 thats what i did and it ran better than stock Yes this was before i did anything else to the motor but if your on a budget run yamalube it is cheper than klotz
greg86hd
Sep 16, 2015 12:32 AM
