SPUTTERING PROBLEM
Old Mar 2, 2008 | 08:35 PM
bisom's Avatar
Default SPUTTERING PROBLEM
I have a 1996 300 ex, has been rebuilt top end, at 1/3 throttle and above it sputters real bad, have change carb, have tried different coil, it runs perfect at idle and good takeoff torque, Dont know how to check cdi , battery is chargeing lights and nuetral lights are working
please any suggestions
thanks
Old Mar 2, 2008 | 08:45 PM
TractorPacker's Avatar
Do you have a balloon?
Did you double check your cam timing? I put a 300ex back together and was one tooth off, on the cam timing. It would let compression come back through the carb, thus making a sputtering sound.
Old Mar 3, 2008 | 08:48 AM
bisom's Avatar
I will double check it, the sputtering is engine skiping, might be a beter description
thanks
Old Mar 3, 2008 | 12:32 PM
hondabuster's Avatar
Seeing how throttle input is related to the issue..sure sounds like a carb problem. Are the connections on correctly and tight , at the carb?
Old Mar 3, 2008 | 07:18 PM
bisom's Avatar
I double checked the timing chain its ok
Old Mar 3, 2008 | 07:20 PM
bisom's Avatar
I agree i think is the carb but changed it with a known good one and also looked the boot over good
thanks
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
hondarider1234
Jul 21, 2015 11:53 PM
