POLARIS 450 OIL OVERFULL
Old Mar 2, 2008 | 10:11 PM
450 MAN's Avatar
Default POLARIS 450 OIL OVERFULL
Noticed my oil level was low on my 2006 450 sportsman so i add some. Now when the oil is cold it shows a little overfull. Is this a problem.
Old Mar 2, 2008 | 10:36 PM
sjbr549's Avatar
it should be ok. it might spit it out of the vent line though
Old Mar 2, 2008 | 10:39 PM
450 MAN's Avatar
what vent line and where is located?
Old Mar 2, 2008 | 10:44 PM
Mongrol's Avatar
"Official Site Skeptic"
Its in the airbox. Check for oil in there.
Old Mar 2, 2008 | 10:47 PM
450 MAN's Avatar
so the extra oil will not harm the motor or blow the seals in any way!
Old Mar 2, 2008 | 10:48 PM
sjbr549's Avatar
not sure where they are on you quad. they'll look like little rubber gas line coming off the engine case going nowhere. works kindof like a pvc valve. if you have the owners manual it should show them.the gas tank has some and if it's carb it'll have some too
sheepdogMSP8117's Avatar
The only reading that matters is what it shows when you follow this procedure:
Straight from the manual
1. Set machine on a level surface.
2. Start and run engine for 20-30 seconds. This will return oil to its true level in the oil tank.
3. Stop engine, remove dipstick and wipe dry with a clean cloth.
4. Reinstall dipstick, screw the dipstick into place.
NOTE: The dipstick must be screwed completely in to ensure accurate measurement.
5. Remove dipstick and check to see that the oil level is in the normal range. The oil should be between the top line and the bottom line on the dipstick. Add oil as indicated by the level on the dipstick. Do not overfill.
Old Mar 2, 2008 | 10:51 PM
Mongrol's Avatar
Its not an ideal situation. Consider draining abit. They talk about being had on seals but don't know for sure. I over filled my 400ho by 16 oz, took 8 out. Seems to be ok but still overfill.
Old Mar 2, 2008 | 11:35 PM
450 MAN's Avatar
After topping up my oil I went for a 1 1/2 to a 2 hour run and every thing seemed fine hope things stay that way.
Thanks for all your help.
Old Mar 3, 2008 | 07:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
iput in the amount the manual says and never worry about being over or under when i change the oil and when i check it i start and run it for a bit then shut it off and check.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
