250 2x4 auto or ozark
Old Mar 3, 2008 | 04:11 AM
rv's Avatar
rv
Default 250 2x4 auto or ozark
hes not an sgressive rider so i feel eather one will do is the 250 2x4 a reliable machine is my main concern and how does it handle on uneven terain ?
Old Mar 3, 2008 | 08:30 AM
papahouse's Avatar
This appears to be a very solid quad, I have driven one and it as plenty of power
The Jianshe Spam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word  (Mountain Lion) JS250 ATV
Available 250 is semi automatic (Clutchless) allowing one hand free to spray weeds or hold a rifle. The brilliant 250cc air-cooled Engine is also equipped with a recoil starter as back up in the advent of the battery going flat so that the engine can still be pulled back into life. This model has also been sold in Australia by a reputable Japanese brand whom is a share holder in JIANSHE CHINA.
Jianshe Spam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word  JS 250 ATV
Engine Type : Overhead Cam Single Cylinder
4 Stroke, Air Cooled
Bore x Stroke (mm) : 71 x 58
Piston Displacement : 229.6 cc
Ignition : Electronic C.D.I.
Spark Plug : ND X22ES-U Gap 0.6-0.7mm
Compression Ratio: 8.7:1
Maximum Power (kw/r/min) : 11/8000
Maximum Torque (N.m./r/min) : 13/6500
Starting System : Electric/Recoil starter
Charging System : AC Magneto
Battery : 12N14 - BS/12v, 14Ah
Head Lights : 12v , 25w/25w x 2
Tail Light : 12v , 10w x 1
Transmission :
5 speed Constant Mesh semi auto clutch with Reverse. 0-1-2-3-4-5
Ratio's:
1st 34 / 12 (2.833)
2nd 34 / 19 (1.789)
3rd 29 / 22 (1.318)
4th 26 / 25 (1.040)
5th 23 / 28 (0.821
Primary reduction : 73 / 22 (3.318)
Secondary reduction : 19 / 18x46 / 11 (4.414)
Final Drive : Shaft
Brake (Front/Rear) : Drum/Drum
Tyre Front : AT22 X 7-10
Tyre Rear : AT22 X 10 -10
Fuel Tank Capacity : 12Lt Reserve 1.6Lt
Front Suspension : Macpherson strut Independent Suspension
Rear Suspension : Mono shock Swing Arm
Suspension Travel : Front - 125mm
Rear - 135mm
Parking Brake : Mechanical Lock
Max. Load Capacity : Total Load 165kg
Front Rack 30kg
Rear Rack 45kg
Tow Capacity 330kg
Engine Oil Capacity : 1.6Lt 15w - 40w
Gear Oil Capacity : 270ml Gear Oil 80 API GL-4
Dry Weight : 220kg
Rider Capacity : 1 person
Frame : Steel Square Tube
Caster Angle - 4 Degrees
Trail - 20mm
Seat Height (mm) : 780mm
Wheel Base (mm) : 1160
Overall Height (mm) : 1120
Overall Length (mm) : 1960
Overall Width (mm) : 1010
Ground Clearance : 155mm at lowest point diff
Turning Circle : 2900mm
Old Mar 3, 2008 | 02:22 PM
kickass210's Avatar
well i have an ozark id think gearing would be better than an auto in that size but . ac has a nice digital latout etc.
Old Mar 3, 2008 | 03:57 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Since he's not an agressive rider than the auto would probably work best. Especially if by 'not agressive' you also mean that he's not the most skilled rider. Having an auto gives him one less thing to have to worry about - always in the right gear etc. AC has one (made by Kymco) that looks pretty good - high and low range and pretty peppy.
Jaybee
Clint Russell
Sep 25, 2015 03:20 PM
clscott84
Sep 21, 2015 10:16 AM
Alex G.
Sep 19, 2015 06:34 PM
that1redhead
Sep 8, 2015 11:47 AM
traumajunkie
Jul 5, 2015 03:03 PM
