Popo 800 strange behavior
Old Mar 4, 2008 | 04:34 PM
snootdog's Avatar
Default Popo 800 strange behavior
My 800 check engine light came on while plowing snow in Ohio...the bike started sputtering while going forward when giving about 1/2 throttle(machine acts kinda similar to the way it would act if giving full throttle in reverse w/o hitting the overide button) Dealer said it threw a code because I didnt let it warm up enough before running it hard causing the machine run rich (even though it is efi) and throw a code. Dealer claimed it is not uncommon when machine is run hard w/o proper warm up. I admittedly did not warm the bike up for long( i was in a hurry). Does this make sense? has anyone had this problem?
Old Mar 4, 2008 | 05:05 PM
sjbr549's Avatar
don't make sense to me maybe someone will know for sure
Old Mar 4, 2008 | 05:21 PM
SPORTSMAN70003's Avatar
That don't make sense. What year is your 800? What was your code number? Some of the earlier 800's had grounding issues with the coil.
Old Mar 4, 2008 | 06:36 PM
Blacksheep5's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SPORTSMAN70003
Some of the earlier 800's had grounding issues with the coil.</end quote></div>
what was the problem? my 07's handle bars shock the sh&t out of me when I ride fast for long periods of time.
Old Mar 4, 2008 | 06:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
unless its throwing a bad air intake sensor which would might make it run extremly rich.
Old Mar 5, 2008 | 10:15 PM
snootdog's Avatar
Its an 07 800 so it shouldnt be the coil problem on older 800's. The receipt on the Repair Order said loss of synchronization with a note that this can be casued by improper warm up...dont know if this is BS or not and I am about out of warranty. This is the only problem I have had with the bike besides the tranny drain plug that was too long.
Old Mar 6, 2008 | 01:23 AM
Kerbbirds's Avatar
we had a machine do that at work, called polaris, and they said that it is caused by improper warmup, just means the crank position sensor wasn't picking up the signal for some reason. not sure why that would be caused by it being cold, didn't realize the temp of the motor could cause electrical problems on the crank sensor
Old Mar 6, 2008 | 02:06 AM
snootdog's Avatar
[img]i/expressions/beer.gif[/img] Thats good to hear...it sounded so strange that improper warmup would trip the code but if thats what you have heard also I know they arent feeding me b.s.
Big bousse
Sep 26, 2015 10:42 AM
essonlaker
Sep 10, 2015 01:12 PM
switzomatic
Aug 24, 2015 12:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jun 21, 2015 02:49 PM
