Help with winch
Old Mar 7, 2008 | 10:25 PM
Elimin8r's Avatar
Default Help with winch
First off, thanks to Stendori for his help. Your "from memory" instructions were spot on. Made it much easier.
Everything is installed and now when I move the rocker switch all I here is a click from the contactor. Either way all I hear is a clikc on the winch cable doesnt move..
Now mind you I got no instructions with this winch but it is a factory installed POLARIS winch off an 06 SPortsman 500. I also have never even used a winch, just watched others.
ANy help would be appreciated.
Matt
Old Mar 7, 2008 | 10:50 PM
sportsman rocks 's Avatar
Is the contactor new our used? Some times moister gets in side the contactor and sticks, check all your connections.
Old Mar 7, 2008 | 10:58 PM
Elimin8r's Avatar
Used. Connections are tight.
Old Mar 7, 2008 | 11:03 PM
Try taping on contactor with rubber hammer, and at the same time hitting the rocker switch in and out fast.
Old Mar 7, 2008 | 11:04 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
make sure the side "FREEWHEEL" switch(lever) is locked in..........Without this engaged the winch will not spool in or out!!!......Caper.........
Old Mar 7, 2008 | 11:35 PM
smiddy's Avatar
Elimin8r,
I had this issue when I installed my winch on my 06 Sportsman. I found that the prewired power cable was not wired into the battery. The end of my power cable near the battery had a yellow shrink tub over the connector that I had to cut off and then connect this directly to the battery post.
Old Mar 7, 2008 | 11:37 PM
I just told him he needs that connected from his other post...........He said he couldn't find the wire at the Battery..........I told him he needs this connected!!!.....Caper.........
Old Mar 9, 2008 | 03:06 AM
Elimin8r's Avatar
Thanks Smiddy, found the wire it was hidden between the frame and the air filter.
Took awhile to fish it out but I got it and its now connected to the battery and guess what? The winch moves!!
Just in time too , we just got about 2ft dummped on us here near rochester NY
Thanks everyone for your help.
Old Mar 9, 2008 | 11:55 AM
Rowe's Avatar
had the same problem with mine. I brought it home from the dealer freespooled it out and hit the button and nothing. Talk about upset. Started looking around and found that they never connected it up. Feels good knowing you have that winch, I never had one before and still havent needed it to get unstuck but just knowing you can get yourself out is a big stress reliever. I have used mine to drag deer up steep embankments though, its great for that.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
