reverse problem on 07 wolverine
Old Mar 9, 2008 | 04:44 PM
miw0lvi450's Avatar
Default reverse problem on 07 wolverine
today my friend and I were just riding around just doin the normal stuff we do when i noticed as i put it in reverse and i started to back it up, it would bog down and start to sputter like it was running on fumes of gas. but when i put in in drive it was fine and ran good but everytime i was backing up it would sputter and bog down. Does anyone know why this is happening? How can i fix it?
2007 yamaha wolerine 450 SE
2004 yamaha blaster
Old Mar 9, 2008 | 08:50 PM
Eimajz's Avatar
sounds like you are maxing out the rev limiter.
Old Mar 9, 2008 | 10:30 PM
miw0lvi450's Avatar
okay. also i would like you guys to know that just before this happend i had went threw pretty deep water about an inch away from the exhaust so if that might have done something please tell me.
2004 yamaha blaster
Old Mar 10, 2008 | 03:28 AM
viper5's Avatar
Does it do this even if you back up slow?? There is a rev limiter that will only come on in reverse so you don't back up to fast and lose control. When it comes on it will run just like you have described. If this is a new thing it started doing maybe you got a sensor wet and it's giving a wrong rpm reading so the rev limiter is activating while in reverse before it should. I would run it around or put it some place warm to dry it out. It doesn't sound serious just sounds like a rev limiter problem
Old Mar 10, 2008 | 07:00 PM
miw0lvi450's Avatar
ok thanks a bunch.
2004 yamaha blaster
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
steveo612
Jul 11, 2015 08:35 AM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
