94 banshee losing 4th, 5th, gear
This sound funny, but dose it only do it when you wear ridding boots? if so adjust shift lever 1 or 2 splines up. this happened to me, and what happened is that the shift lever has to always go to default position before taking next gear, especially when I hammer hard. just looking at the simple things first. I would hate it to be a shift fork. that would suck!
for your information you dont check the oil by screwing the dip **** stick in and checking, you take it out wipe it off and just set it in the hole, pull it out and if its in the middle of the checkers then its good if its to full then not good, could cause rough shifting from to much tranny preasure, but i doubt its that
Jul 7, 2015 11:00 PM
