94 banshee losing 4th, 5th, gear
Old Mar 10, 2008 | 06:09 PM
Bergie's Avatar
Default 94 banshee losing 4th, 5th, gear
i have a 94 banshee im losing 4th 4th and sometimes 6th gear it only happens sometimes when im on the bike hard, racing up a hill, etc any ideas?
Old Mar 10, 2008 | 07:13 PM
ich4bdm's Avatar
my suggestion...buy a raptor (just kiddin). is your clutch alright?
Old Mar 10, 2008 | 10:12 PM
speedyman12345's Avatar
probably a bent shift fork
Old Mar 10, 2008 | 11:55 PM
Squishy's Avatar
This sound funny, but dose it only do it when you wear ridding boots? if so adjust shift lever 1 or 2 splines up. this happened to me, and what happened is that the shift lever has to always go to default position before taking next gear, especially when I hammer hard. just looking at the simple things first. I would hate it to be a shift fork. that would suck!
Old Mar 11, 2008 | 03:45 AM
Bergie's Avatar
Do you think it might be because i hav just a little too much tranny fluid in the crank case i mean its not too much but it is over the line a little?
Old Mar 11, 2008 | 11:17 AM
yotatrailrunner's Avatar
Sounds like your clutch's could also be slipping unless the transmission is grinding
Old Mar 11, 2008 | 06:36 PM
Squishy's Avatar
It's not the tranny fluid.
Old Mar 11, 2008 | 07:30 PM
for your information you dont check the oil by screwing the dip **** stick in and checking, you take it out wipe it off and just set it in the hole, pull it out and if its in the middle of the checkers then its good if its to full then not good, could cause rough shifting from to much tranny preasure, but i doubt its that
Old Mar 16, 2008 | 12:11 AM
woodsjunky's Avatar
if it pops out of gear under hard throttle i would start with the shift cam and the shifting forks it is not the clutch
Kaleb_00
Jun 1, 2016 09:15 AM
HYS
Aug 18, 2015 12:28 PM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
