2003 Warrior with a MISS
Old Mar 10, 2008 | 08:10 PM
cfdwarrior03's Avatar
Default 2003 Warrior with a MISS
this warrior i just bought hasn't been ridin in at least one year. i changed the gas, changed the oil/and filter, changed the spark plug. took the carb apart today and it is super clean. while idling, about every 60 seconds the motor goes to die but only for a milla second then returns to normal. while idling in neutral when i rap on the throttle and let go it takes a second or two for the machine to return to idle, like the throttle cable is stuck or something. ANY IDEAS, THANKS ALOT
Old Mar 10, 2008 | 09:34 PM
viper5's Avatar
When you took the carb apart did you spray carb cleaner thru the jets and the body were the slide rides? Just because it looks clean if it been sitting around for a while it will get gumed up were you can't see it and it can make the slide stick and idle weird
95wolv
Sep 27, 2024 12:00 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Hw00d
Sep 10, 2015 08:53 AM
