front motor mount
Old Mar 13, 2008 | 07:57 AM
wayout's Avatar
Default front motor mount
my atv creeps when you put it gear,especialy in low gear,i was told to check my front mount to make sure it wasn't busted,well i did so,i don't think it's broke,but i did noticed on the left side setting on the atv,their's a piece of medal that goes around half way of the bushing on the left side,would some of you guys care to check to see if yours are like that,you would think that it would have medal all the way around or none at all,not just half way,thanks in advance.wayout,out..............
Old Mar 13, 2008 | 09:11 AM
Kerbbirds's Avatar
thats what the mount looks like, did you use a bar to pry on the mount to check it, if its not the mount you might have clutch alignment problems or the ebs washers are worn in the primary.How high is it idling.
Old Mar 13, 2008 | 05:02 PM
wayout's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Kerbbirds
thats what the mount looks like, did you use a bar to pry on the mount to check it, if its not the mount you might have clutch alignment problems or the ebs washers are worn in the primary.How high is it idling.</end quote></div>
no i didn't use a bar,i put it in gear and give it a little gas and watched to see if it moved,you know the same way you would check a car,my idle is about 1200,i just have about 500 miles on it,seems to me,i could be wrong but i think it's always done this,i can't really remember,hell it's brand new,i was just tring to fix it myself,i hate taking it to the shop,i know they will keep it for a month or more,you know what i mean,thanks for your imput,,wayout,out.............
JackTheKing
Jul 14, 2015 09:09 PM
cornermike
Jul 8, 2015 11:44 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
