2004 Honda 450es foreman
Old Mar 13, 2008 | 09:56 AM
Flying's Avatar
Default 2004 Honda 450es foreman
I guy's , I'm new at this sight so please bare with me. I have a Honda foreman 2004 450es. The other day I was riding down the road mid speed and when I came to the stop it would not gear down ! I was in 5th gear and the #5 was flashing 8 times in each set.I turned off the bike and when I turned it back on I could shift down O.K. 10 min later it did it again.(some slush on th road) After that it was ok until I preasure washed it 2 day's later. This time it flashed ( N ) 8 times while in neutral. I'm sure water is my problem but what should I do ??Please help.
Old Mar 13, 2008 | 12:29 PM
hondabuster's Avatar
Pressure washers causes lots of problems. It forces high pressure water where it shouldnt be..like past seals and covers, and into electrical connections.
8 flashes is for the angle sensor system, most likely there is water in the connectors at the front side of the motor. Disconnect all the connectors at the front of the motor...one at a time. Dry them out, if nothing else, just sitting in the warm sun should do it, and then make sure the connections are clean and shiny, and not dull or corroded. Then apply dielectric grease to both sides of the connections, and reconnect them.
This should fix the problem, but if it doesnt, just reply back to this thread.
Welcome to the forums.
Old Mar 13, 2008 | 12:44 PM
Flying's Avatar
Thanks a lot I'll get some dieectric grease,clean and dry connections and give it a try. No more preasure washing for me..
greg74
Sep 10, 2019 03:03 PM
bigred20653
Aug 31, 2015 12:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
