what's the biggest tire i can run!!!!!!!!!!!!!!
Old Jan 16, 2001 | 09:45 PM
hondaboy5's Avatar
what's the biggest tire i can run on my lakota
the size is 22-11-10 and there not many good tire in that size anyone know a good tire that size
anyone have pic's of there lakota
ANY ONE THAT HAS A LAKOTA IS YOUR CHAIN REALLY LOOSE WHEN IT'S NOT RUNNING BUT WHEN I KICK MINE IN FIRST IT TIGHTEN UP DO I ADJUST IT WHILE IT'S IN FIST RUNNING THANKS FOR ALL THE HELP
Old Jan 21, 2001 | 07:12 PM
AndyB2's Avatar
maby 25 inch
Old Jan 25, 2001 | 09:15 AM
325boss's Avatar
hi hondaboy,
you do need your chain tightenned and i'll explain why, when you put it in gear, the top of the chain is pulled as the drive sproket tries to make it turn. the part of the chain that is loose and floppy then is on the bottom, where you can't see it, cause no power is going there. try putting it in reverse, that "Should" make it loose on top again. but wheather or not that happens, i think it needs tightenned, my 325 boss did that the first month we had it. Then i tightenned it and haven't had to tighten it for the past 6 months (gotta love polaris's new Concentric Chain, NO ADJUSTMENTS!!!) anyway, tighten it like you normally would, and it will be fine, good luck, and keep ridin
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
