Honda 440 big bore kits
It depends on some factors. The machine shop is important, so is the compression you go with. If you go to 12:1 compression you will need a stud kit, most likely. If you get a 11:1, you should be alright. You also need to be aware of heating problems, because the 89mm cylinder wall is thin and can over heat easily.
I am a believer in the 87mm (416) 11:1 compression. If I was to build another 400ex, this is the biggest I would go. With a good cam and decent port job, the quad could run with stock 450's.
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
TLC
Jul 11, 2015 02:28 AM
