Honda 440 big bore kits
Old Mar 13, 2008 | 09:35 PM
MIDZUKI's Avatar
Default Honda 440 big bore kits
What is the reliability of these kits?
Old Mar 14, 2008 | 12:06 AM
TractorPacker's Avatar
Do you have a balloon?
It depends on some factors. The machine shop is important, so is the compression you go with. If you go to 12:1 compression you will need a stud kit, most likely. If you get a 11:1, you should be alright. You also need to be aware of heating problems, because the 89mm cylinder wall is thin and can over heat easily.
I am a believer in the 87mm (416) 11:1 compression. If I was to build another 400ex, this is the biggest I would go. With a good cam and decent port job, the quad could run with stock 450's.
Old Mar 14, 2008 | 09:20 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
use the oem studs!!
Old Mar 14, 2008 | 10:27 PM
MIDZUKI's Avatar
who do you think sells the best sleeve and piston combo?
MIDZUKI's Avatar
for the 416cc
Old Mar 15, 2008 | 12:17 PM
SANDMAN430's Avatar
call powroll they are great
Old Mar 15, 2008 | 08:31 PM
416 and 426 are done with the stock sleeve. Not until 89mm (436cc) do you need to resleeve.
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
toonces
Aug 5, 2015 05:55 PM
ghost civic
Jul 27, 2015 03:15 AM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
