Engine bogs down
Old Mar 14, 2008 | 12:48 AM
thenewshooter's Avatar
Default Engine bogs down
If I hit a decent size puddle of water my sons Kazuma just looses power. Could this be because the engine is rapidly cooled or from the carb sucking in steam? Has anybody put a engine splash guard on there Kazuma? Did it help? I am also wondering if anyone has modified the intake tube from filter to carb.
Old Mar 14, 2008 | 06:59 PM
DeerForce1's Avatar
It sounds like the air filter got wet & couldn't pull enough air. My youngest son has the real small 4 wheeler & when we went out last time he kept soaking his air filter with water in the same holes my 5 & 9 year olds were going thru on their taller 4 wheelers with no problem. I need to snorkle the smallest one. I just pulled the filter & blew it dry from the inside out with compressed air. Just don't blow from the outside in or use to much pressure.......................................... ......DF1
Old Mar 16, 2008 | 07:22 PM
When it took out the filter there was signs of water getting in. So I blew that out also. I also tried some foam pieces to help stop some of that. Only then it was starving for air. I got off and pulled them out, much better. Then the carb stuck open. After taking the carb off. I realized that the rubber boot that connects to the carb had cracked. So off to the parts store, but nothing would work. Then I realized that a inner tube from a pedal bike worked great. Finally got the darn thing is running good again. On Saturday the thing ran like a champ! Even got if stuck in the mud a few times. Even outlasted my friends Badger!
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
