400EX tires
Old Mar 14, 2008 | 09:51 AM
sweetlou's Avatar
Default 400EX tires
I was looking on buying some rear tires for my 2002 400EX and still have the originals on the quad, they are 20 x 10 - 9. Now when I ride I seem to get stuck in many ruts riding up north in NH in the woods, the back end high sides. Now buying tires with a higher ride height should help but would it effect the quad in other areas? Also could I buy a larger dia rim say a 10" and is a wider tire maybe an 11 inch width any help?
On another note my rear skid plate is also a problem, I noticed mine goes straight across rather than having indents for in between the chain and the disk. My friend seems to have a much easier time with his 400ex with that rear skid plate.
Old Mar 14, 2008 | 10:27 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400EX tires
When I want more ground clearance, I run ITP Holeshot XCT's which are 23" front/22" rear...4 ply front/6 ply rear and virtually indestructible. Taller tires in the rear will raise your effective gearing (you will lose low end power...but gain top end speed), which isn't a good thing for a trail rider. So, a little gearing change will help, and is relatively inexpensive. I have tried going one tooth smaller on the front sprocket, but it was to much. It got wheelie happy, and I couldn't keep the front end on the ground. I found a good compromise was to go 1 tooth larger in back (1 tooth in front = 3 teeth in back).
If you don't want to go that tall, the ITP Holeshot H-D's were make for your type of conditions!!! They are 22" front/20" rear, and they would probably be my first choice if it were me. They are 6 ply and again, indestructible.
A word about rims. I run ITP Baja 9X9" rear rims, which are wider than stock and have a greater offset. This, combined with wider tires makes the quad around +3" wider in back and +2" wider in front....for a very nice increase in cornering stability...yet it isn't so wide that it won't fit down a narrow trail.
Old Mar 14, 2008 | 10:52 AM
sweetlou's Avatar
Default 400EX tires
Thanks for the help reconranger.
Old Mar 14, 2008 | 03:28 PM
asfasasu3's Avatar
Default 400EX tires
One thing to remember, almost all tires are different heights. I mean, a 20" I-razr is alot shorter than a 20" razr2, and so forth. The stock tires are short compared to alot of other 20" tires. My stock tires are atleast 1" shorter than my sons razr's.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
