spark plug threads stripped
Old Mar 15, 2008 | 07:40 PM
pantera1973's Avatar
Default spark plug threads stripped
hello all i have 2 sunl 110s one runs fine the other i have had many problems with i have had them for a year and half. I stripped the thread out for spark plug. was thinking about just putting a 12mm plug in would that work?or should i use a thread insert? thanks to all that reply!
Old Mar 15, 2008 | 08:01 PM
Buyingchina's Avatar
Hi. What size are the threads on the original plug?
I have machining experience and may be able to provide some in site that will help you make a decision.
I'm curios to know, have you been using a torque wrench, and how many ft/lbs are you using? This could help others to avoid this problem your having.
Edit; Please provide the numbering info on the spark plug its self.
Thanks, Buyingchina.
Old Mar 15, 2008 | 08:42 PM
original plug is 10mm x 1.75 .500 reach drilling and tapping hole is no problem a thread insert or helicoil for a 10mm plug is same size and thread as a 12mm plug just wondering if a bigger plug would have less spark with stock ignition. i do not use a torqe wrench and dont have numbers right now im at work thanks
Old Mar 15, 2008 | 08:55 PM
Hi. Looks like your asking more of an electrical question that I miss read.
Some one else will have to help you with that.
Thanks Buyingchina
Big bousse
Sep 26, 2015 10:42 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
