WET WOLVIE NO MORE
so i was out riding friday night and i saw a creek crossing it started out about 8inches deep no problem then it droped off to about 6 feet. needless to say i sucked up enough water to make my oil look like thick *** milk. the next day i drained the oil and visted my local yamaha to spend 140 bucks on oil filters ect....well i've changed the oil and turned it over a few times to blow out the water hoping it would start. well after a few hours and no luck i drained the oil... still white but not as bad....anyways to make a long story short she has new oil in her again and still wont start. i've tried starting fluid and no dice...any idea's.
thanks in advance for the help
well i posted this almost a year ago on april 8
and after all this time it came down to a woodruff key that was sheered off. such a magical little piece of metal. actually i hate it. after doing everything in the book it was that. so she running again. now i just have to re-lube the V-belt its shifting kinda hard. happy riding all
it took a year cause i'm lazy and like i said everything pointed to carb trouble and i'd mess with it get frustrated stop for a bit ect... as for the woodruff key it's on the crank shaft and it keeps the stator in the right position it wasnt hard to replace beside needing a special tool to pull the stator and then trying to find the tool because no site that sells it has it listed for a wolverine. it's the same as the wolverine 350 kodiak 400 ect. so that took awhile to find. but yeah i guess it makes it actucally fire at the right time cause when i replaced it. she started up just like new
another thing i learned the hard way on the right side as you sit on it where the V-belt is there is a little plug make sure when ever you get done riding through water and **** you pull it out and drain the water.
