86 engine, 95 frame, will it work?
Old Mar 17, 2008 | 08:57 PM
Ragged_ol_86's Avatar
Default 86 engine, 95 frame, will it work?
My engine on my 95 is knocking. I found an engine from an 86 with carb. will it fit the mounts and frame? also isnt the 86 one of the more wild motors and not so tuned down? The guy says he sees no scoring on the piston through the ports.
Also. my transmission keeps puking thru the over flow. any suggestions? im using 10-40 like i was told to. Help.
Thanks
Old Mar 17, 2008 | 10:25 PM
drlang's Avatar
Check the buttons on your primary clutch. It'll make a heck of a noise when those go south.
Old Mar 17, 2008 | 10:33 PM
It ain t that. sounds like marbles in the case. plus i have a little play in the crank an rod end bearings. Imma gonna run it till it nukes.
Old Mar 17, 2008 | 11:12 PM
ftwflh's Avatar
I think you will need to use the 86 clutch cover because they bolt to the engine different you may also need the 86 CDI.
The tranny needs chain case lube not motor oil
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
NewHillBilly
Jun 14, 2015 11:42 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
toysoldier76
Mar 29, 2000 08:04 PM
